2005 CLK55 Coupe
Old Mar 8, 2021 | 11:17 PM
Aaron68's Avatar
2005 CLK55 COUPE
2005 CLK55 Coupe
Hey guys,
Im a little confused, Im in process of changing my transmission fluid, but wanted to make sure which fluid to use. Reading through different treads, some say the correct updated fluid to use is 236.14 spec and some say to use the older 236.10. Any ideas? Also, does it really matter which brand to use, say original MBZ, Pentosin or Fuchs?
Your input would be much appreciated.
Thanks,
Aaron
Old Apr 8, 2021 | 07:36 AM
Fidel_CashFlow's Avatar
CLK55
I would recommend getting the kit from FCP euro. It comes with everything you need and depending on how much of the transmission fluid you drain, you might need to get an additional 5 quarts (also sold on there)
Old Apr 8, 2021 | 10:21 AM
MattCordell's Avatar
C43 AMG with a tune up
Previously tranny oil bottles were marked as ATF 134, now this transmission oil i re-labeled as 236.14
