M113K Heads on M113 NA Motor
Subscribe
Nov 13, 2021 | 11:32 AM
Has anyone tried this, or know if it will work? I tried to do some research but i haven't found anything on the forums.
It looks like the exhaust ports on the 113k heads are a little over 3mm larger. I understand its a ton of work for such a little gain, but i'm thinking if you do cams at the same time it may be worth it.
Reply 0
Nov 15, 2021 | 01:36 PM
You will lose a little compression. The chamber on the K heads is 2-3cc bigger.
Reply 0
Nov 16, 2021 | 12:55 AM
I wouldn't - you'll LOSE power unless you add the supercharger or some other form of forced induction. I'm not sure the cams are any different.
The M113k engine from what I recall also has beefier internals (forged pistons/rods, etc), so there's that too...
Reply 0
Dec 2, 2021 | 07:47 AM
just go all the way to m113k engine, with msc headers you will be making ton of power. i have kleemann cams that i'm selling if you want even more
i kept my car NA and did everything that can be possibly done without going too crazy and i'm just around 375hp to the wheels(p&p heads, enlarged TB and intake manifold inlets, 2.5 dual exhaust with msc headers, more aggressive cams from w203/w209 amg, and some other tiny changes). with m113k engine in the w208 you will be putting down closer to 400hp with a fraction of cost and better all around engine. just my advice, that seems to be the best mod to do for our cars.
Reply 1
Dec 5, 2021 | 11:32 AM
You will lose HP, it’s a downgrade. The NA heads are better heads
Reply 1
Dec 8, 2021 | 12:58 PM
Quote: You will lose HP, it’s a downgrade. The NA heads are better heads
if i have the NA heads should I port and polish those and swap them on to my M113k then?
Reply 0
Dec 10, 2021 | 10:55 PM
It is true the NA heads are more desirable for performance.The M113k cams are specifically machined to each head as well. It is not recommended to swap cams on the K heads without some careful measurements.
The NA heads flow better on the intake side according to some of the W211 folks who get wild with mods.
The K engine has lighter pistons heavier rods and custom flywheel and balancer.. The K heads will bolt on and have no EGR port on the passenger head.
Hope this helps a bit any feedback welcome.
Good luck with your build.
Best, Gator
Reply 0
Sep 20, 2023 | 05:31 AM
2000 ml55 heads or cams on 2003 ml500 motor
Quote: just go all the way to m113k engine, with msc headers you will be making ton of power. i have kleemann cams that i'm selling if you want even more
can the ml55 heads / cams & injectors be swapped over to ml500 ? I have a ml55 in a junk yard near me so nows the time cause I also need to replace the head gaskets on my 2003 ml500 because my girlfriend drive it without the overflow cap on until it overheated 🥵. So while I have the opportunity to rebuild my m113 motor I would like to upgrade the performance possibly with the ml55 camshafts or even the complete heads ! . Good news that leads me to believe I can do this swap is on FCP euro site it says the same HG kit for my 2003 ml500 will also fit the 2000 ml55 . My next question is would I need to reprogram the ecu on my ml500 if I perform this swap ? I assume yes . Thanks 🙏
Reply 0
Explore
Subscribe
Currently Active Users (1)
