Poly front upper control arms?
Did you do these yourself or have a shop do them? Were they a PITA and did you need any special tools to install them? Im looking at replacing all of mine here soon as well, looks like the kit they sell is great.
But bonus is there also Camber and Caster adjustable. Same for Rear - ‘4’ bushes that are Camber and extra Toe adjustable
OEM / Factory there is only basic front and rear Toe directional adjustment.
No Camber (or Caster) allowing to adjust tire contact angles spread load more evenly to resolve costly premature excess edge tire wear.
FRONT W211 Camber only #502216-1i $345 (Both Sides)
Camber & Caster #502216K $480 (Both Sides)
FRONT Upper Arm Bushes “Camber & Caster” #502216-2J $380 (Both Sides)
REAR SUSPENSION (Also all W211 incl. AMG)
Lower arm Camber (& Extra Toe to compensate for addition of rear Camber adjustment)
AIRMATIC #502526K $480
COIL SUSP. #502126-1K $480 (Both Sides)
ALL K-MAC FRONT & REAR ADJUSTER KITS SPECIALLY DESIGNED SO NO NEED FOR SPECIAL TOOLS OR TIME CONSUMING CONTROL ARM REMOVAL.
ALSO MANUFACTURE:
UPRATED BUSHINGS - for the '6' Rear Multi Link Arms - Tauter response, Less rear end flex, twitch, loss of traction. Especially when applying power to lane change / overtake #502528K $480
SEE WEBSITE RE W208, W209 MODELS.
AUDI to VOLVO - K-MAC Experience Of Resolving OEM Suspension Shortcomings Since 1964 !
