Biggest exhaust diameter?
Old Feb 5, 2022 | 11:22 PM
Fidel_CashFlow's Avatar
CLK55
Does anyone know if a 3in true dual exhaust can fit on the coupés? Or what the biggest exhaust diameter i could run with no interference? I'm pretty sure a 2.5 pipe could fit just fine as a true duel exhaust but since im running a M113K they say to try and have the biggest exhaust for boosted platforms.
Old Feb 7, 2022 | 04:31 PM
Rutdipper's Avatar
2004 CLK55 AMG
Your cars a w209? I built a custom true dual exhaust on my 04 CLK55 so know every tight spot. A dual 3” should be fine. The one spot that’s an issue is the right side rear sway bar. It doesn’t have a bend in it like the left side for exhaust clearance. I’ve seen other peoples dual setups where they went up & over the right (passenger side) of the sway bar but it requires a funky kink in the pipe to do that. It’s good for clearance & looks nice when looking under the car but bad for performance. I personally chose to go under the sway bar. I wanted my exhaust to be a free flowing as possible with no unnecessary bends…It hangs a little low in that spot but because it’s in-line with the rear tires I don’t have any issue with scraping.
the next thing I’d say is on a 3” dual setup you will most likely have to run a single 2 in 2 out muffler in the center of the car. I don’t think you’ll have space for 2 mufflers
Old Feb 7, 2022 | 04:41 PM
CLK55
this is the info I needed! Thank you so much and no its going to be a straight pipe with an H-pipe in the center
Old Feb 7, 2022 | 11:55 PM
tlambert's Avatar
2005 E55 AMG
If you have complete under car pics of your exhaust would you mind posting them. Might be some help for me also.
Thanks!
Old Feb 8, 2022 | 08:13 PM
Rutdipper's Avatar
2004 CLK55 AMG
Thanks!
Sure…I’ll take some & post them.
Old Feb 8, 2022 | 08:16 PM
tlambert's Avatar
2005 E55 AMG
Thank you.
I have an 03 CLK55 that I want to do. This will be a help of what’s ahead.
