Headlight issue
First I replaced the ballast which worked. But I kept killing cheap amazon ballasts. (3 of em @ $35 a piece)
Upon closer inspection, the wiring inside the headlights was decaying and likely rubbing together and shorting out. I first repaired the wiring (sloppy job) which worked for awhile. But then it shorted out again due to my hack job.
The final solution was to pull two used headlights from my local pickNpull for $45 each. Problem solved!
It's crucial to make sure the headlight covers stay in place. Otherwise the heat of the engine makes it way inside the headlights and decays the wiring. The previous owner had removed both headlight rear covers for some reason and I think that helped cause the issue.
