CLK320 serious electrical issues
Old Aug 2, 2023 | 06:58 PM
bergfurher's Avatar
I have a 2002 clk320 convertible that developed a massive series of issues. First, I had no third brake light, and a warning on the dash. Checked the light, seems fine, no damage to the wires from the lid to the quarter panel. Next, when in reverse, no reverse lights, gone. Then is started to get worse! Scanned the car, got P1817-2 code "reverse lamp has short circuit to battery". Then the gauges light go on when in park, but hit the brake and the light go out in the gauges. Then, all the lights in gauges started flashing on and off very fast, all light in the gauges. I can start the car, but off lights in the gauges now flash every second. The cooling fan comes on strong, until I hit the brake pedal, and all goes back to normal. Re-scanned the complete car and had fault codes on every electrical part on the car! The P1817-2 code will not clear, all other fault codes I could clear one at a time. I changed the brake light switch, nothing. Finally had to dis-connect the battery or else it will go down fast. Battery is 5 years old, and tested shows replace, but the car starts fine with it. The gauges have stopped going nuts, and now there is a flash to the gauge lights every second, unless you hit the brake pedal. Makes no sense. Really need help here please. I have read on the forum several things, from SAM, to ECM, damaged wire to trunk lid etc.
Old Aug 6, 2023 | 04:53 PM
waveterrorist's Avatar
Firemist O5 CLK55 Cab Silver 05 CLK55 Coupe Tanzanite 06 CLK500 Coupe
First thing to do is try a known good battery....
