Help with M113 TPS location
Old Sep 5, 2023 | 10:16 PM
williamsaylor23's Avatar
Crossfire
I have a question. I have a M113 that is getting wired into a crossfire. The wiring is almost complete and the project is almost finished. (Ecu and things have already been reprogrammed). I got a nitrous kit that hooks to the TPS via a wire that will turn on/off the spray based on pedal position. My mechanic currently has the engine but not the nitrous kit. My question is, where is the TPS wire that I would need to splice into, I’ve gotten mixed messages researching online between on the engine by the throttle body and also inside the car on the pedal assembly. I realize that if it is the pedal assembly then you guys may not know the answer but if it is the engine can you please help me with location and color of the wire. For reference incase anyone is wanting to know I have the ZEX 82023 system.
