Would you put this transmission mount on or keep the old one?
Old May 15, 2024 | 03:29 AM
Shark7000's Avatar
2008 CLK-350 Convertible X 2
I ordered from partsgeek. This is what the transmission mount looks like. The old one doesn't actually have a tear or rip in it. Just the very beginning of one, but it is stiffer than this new one with thinner rubber. I needed the motor mounts, but for a bit more money, this is a complete 3 piece set. The motor mounts look fine, but this transmission mount looks weak. The oil filter housing seal was just there because I need to change it. I didn't even realize it was in the picture until I uploaded it. LOL
2008 clk350 convertible.
Old May 15, 2024 | 12:35 PM
JohnLane's Avatar
222 S-65
Re-install the old trans mount and measure where the trans 'hangs' at.
Compare with the new one. If the same chances are the old one is fine.
Also compare quantity of vibrations in the car with old vs new.
Your 'Old' trans mount doesn't look bad (without weight on it).
Old May 15, 2024 | 12:46 PM
PHILLYCLSJOE's Avatar
2002 CLK55 AMG: 2004 S55 AMG: 2009 C63
OP i Bought a new trans mount not too long ago and thought they sent me a defective unit as well. It looked like the mount was ripped, however its actually just excess rubber from the mold when they are made. If you stick your finger in there you'll see what i mean, its just a very thin layer of rubber that wasn't cut out of the mold.
I would install the new one personally. The trans mount I removed from the car looked fine as well, however i installed the new one. It fixed the vibration issue i was having at 1300rpm so i would recommend replacing it with new even if the old one still looks good.
- Joe
Old May 15, 2024 | 01:52 PM
Shark7000's Avatar
I guess I will try using it. I'll save the old one in case it goes out, since it has almost half the amount of rubber holding it. That back section, at the center of the mount, is very thin and doesn't add any real strength to the mount.
