2003 CLK55 AMG Crank but no Spark
Hi all,
I have a Mercedes-Benz CLK55 AMG (209.376) with the M113.987 engine.
The alternator recently failed while driving, which caused the battery to go flat and the car to shut off. After towing it home, I charged the battery and tried to restart the car. It cranks, but there is no spark.
Before the alternator failure, the car ran perfectly with no issues.
What else could be preventing spark in this situation?
What I’ve checked so far:
- Fuel: Present
- Air intake: Good
- Compression: Good
- Crankshaft position sensor (CPS): Replaced with no change
- Battery: Brand new, holds charge
- Spark plugs: Removed one and tested—no spark
- Error codes: None related to ignition in any system
- Fuses (front SAM): Inspected, all good
- Wiring: Looked over generally, no in-depth tracing yet
Current suspicion:
- Something may have triggered when the battery went flat—possibly the immobilizer/anti-theft system or another system that disables ignition.
- Tried multiple diagnostic tools but couldn’t perform special functions on the immobilizer system.
- Diagnostic readout shows:
- Immobilizer = NOT ACTIVE
- Start Enable = YES
- Status of Drive Authorization = Immobilizer is Activated
Waiting for new unit. Also found problem, it was in fact the fuse for the coil packs when checking it all looked good, but i didnt bother testing each one properly and thats on me but that was the issue, car starts now normally.
