CLK63 Black Series Forum & Registry Information and discussion on the W209 CLK63 AMG Black Series and Registry for all owners.
Weight Question
Old Nov 24, 2008 | 02:40 PM
kevinpuri's Avatar
'95 S500 '93 500 SEL
Weight Question
Is it true that the BS weighs more then a CLK63?
1760kg on the BS
1755 kg on the CLK 63 coupe
After all that was removed why does it weigh more?
thanks
kevin p
Old Nov 24, 2008 | 02:53 PM
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
Bigger brakes, bigger wheels, thicker and longer axles, heavier and longer control arms, heavier coil-over suspension, springs, plus remote shock resevors, rear strut tower brace (reg CLK 63/cab only have front), beefier internals in the liited slip rear-end, dual mufflers, wider heavier rear fenders. This stuff adds up pretty fast.
Old Nov 24, 2008 | 04:13 PM
kevinpuri's Avatar
thanks for the indepth anwser. Makes sence
Would you know where i could find larger images of your car or other evo BS's ?
I would like to have some high quality photos printed and framed.
Thanks again,
Kevin
Old Nov 24, 2008 | 06:59 PM
alexander stemer's Avatar
CLK 63 AMG Black
Plus the multiple oil coolers. AS
Old Nov 24, 2008 | 08:29 PM
jrcart's Avatar
Yep, I forgot about those, probably a few more "beefed up" parts we are still overlooking as well.
Old Nov 24, 2008 | 10:43 PM
CLK 63 AMG Black
And the little plaque that says "Black Series". It's small, but really heavy. Plus, there are no symbols carved into 13 blanked out accessory buttons. That adds a lot of weight. AS
