Does anyone know how to remove the shift knob...
2012 ML350 Bluetec
Is it a matter of just turning counter clockwise? I just don't know how much force I should be exerting.
not familiar with your model, but if the knob fitment is similar to most other MBs
it is simply a locking collar. palm on knob. reach down with index and thumb
and twist 90 degrees or so CCW (as viewed from top). pull up on knob.
2012 ML350 Bluetec
2012 ML350 Bluetec
2012 ML350 Bluetec
clk 63 black series
CLK BS shift knob unscrews CCW but it's on too tight for factory - so just wrap it well in a folded cloth & apply a large crescent wrench to it & it'll break free
2012 ML350 Bluetec
2008 CLK63 AMG Black Series
And if so, maybe need some to return to this setup after it's removed and installed again. When you screwed yours back on did it align perfect when the threads got tight enough that is was on fully so to say?
Thanks, details help today for this guy, but later for those that search
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
clk 63 black series
It may have had some light thread-lock on it - but I've only unscrewed it twice (it's CF now) so I don't plan on removing it multiple times & find out if it loosens to easily. I know when I screwed it back on 'til it squared-up took alot of torque (by hand) & it's really on there.
2012 ML350 Bluetec
2012 ML350 Bluetec
Just by the size, you will need to custom make a new shifgate surround. As it is, the c63 shift gate surround will gobble up the clk bs shift gate. You could probable use the bs shift knob, but without the gate it's going to look pretty silly.
2012 ML350 Bluetec
Everyone, I did this and it did break free. Unfortunately there is threadlock and it was tight all the way until it came off. I put one layer of terry cloth at some point to cut corners and I shredded the knob. New parts are on order, what an idiot i am (expensive 2 second mistake).
(name?, I ain't gonna type all that, but I typed all this ;-), so will just say "dude", sorry to hear the learning mistake, hope the knob was not too much $$. Thanks for the update, hope it saves the next owner, that's whats nice about forums, share the knowledge, share the wisdom (a fancier word for I already broke something doing that, learn from me) share the fun, and the pain
Someone said maybe a white color on their threads, is white the color of the leftover threadlocker on yours? I am sure there is threadlocker from more than just Permatex, so their common blue and red mixes are not the only colors to be found but was it maybe light blue by chance?
2012 ML350 Bluetec
That would make sense, Permatex blue mixtures are typically medium strength, reds more permanent. The blue version goes light/light blue after it sets up. If anyone taking theirs off and finding later it moved off of being straight-on could add a small amount of blue threadlocker to remedy that.
2012 ML350 Bluetec
2012 ML350 Bluetec
Important...
For anyone trying to remove this knob, i've already damaged two knobs using standard pliers covered with cloth and padding. Import makes a wonderful soft jaw plier that grips strongly but did not damage the knob's finish. Just a fyi. It's cheaper than replacing the knob which is now $135 + shipping on parts.com. I still placed a rubber glove over the knob just for added protection.
import soft jaw pliers
