CLK63 Black Series Forum & Registry Information and discussion on the W209 CLK63 AMG Black Series and Registry for all owners.
Secret track mode setting
Old Feb 25, 2014 | 11:17 AM
andysclk63's Avatar
2008 CLK63 Black Series
Is there a secret track code setting on a CLK 63 Black Series?
Old Feb 26, 2014 | 09:55 PM
MOFLO's Avatar
That would be cool if there was. The CLKBS is crazy to begin with!
Beside turning off the ESP and S/M trans mode, there are lots fine tuning of suspension and various mods... but no secret track mode.
Old Mar 1, 2014 | 12:33 PM
NYC_Z06's Avatar
CLK63 BS
Right foot to floorboard. And its not necessarily a secret.
Old Mar 1, 2014 | 12:36 PM
andysclk63's Avatar
Dyno Mode
Thanks for advise!!! I find out that it is called dyno mode. Look it up on you tube
Old Mar 5, 2014 | 01:39 PM
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
You can use dyno mode on a drag strip but I would not recommend you use it on a road course. Dyno mode shuts down all traction/stability and ABS. It does not boost hp or offer any performance advantage. The only reason some guys like running it at the drag strip is because you can brake stall the car without cutting power as well as turn off the traction control.
Old Mar 5, 2014 | 02:50 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
run it for a longtime in dynamometer mode and the car will go into limp mode.
