CLK63 Black Series Forum & Registry Information and discussion on the W209 CLK63 AMG Black Series and Registry for all owners.
Limp mode
Old Sep 13, 2017 | 08:47 PM
GeoGeo's Avatar
CLK BS
Originally Posted by Stickstome2
Ok so car is at AMG place . They found the accelator pedal module is bad . He said that's why it was going into ESP limp mode . Might not do it under regular exceleration but mayunder wot or close the pedal tracer sensor will freak out the car . Does this sound right ?
It's not unusual. My BS went into limp mode before and I had a Eurocharged tune. I called them and they say they've replace a few BS with bad gas pedal. Although my car ended up with a fuel line problem and not related to the pedal. But yes it has happened before.
Old Sep 13, 2017 | 09:59 PM
COOPERDB's Avatar
NB8 PARACHUTE
Great post
The more knowledge shared about
the CLK63 BS the better
Thank-You
D.B.
Old Sep 16, 2017 | 03:29 PM
Stickstome2's Avatar
2014 C63 Amg
Also , a track day with ESP off is so much more fun . I used to a little nervous because I didn't want to over do something and slide .however when I was forced to drive with it off ,I drove better and way more fun
Old Sep 20, 2017 | 12:58 AM
2014 C63 Amg
Going to track this weekend . But so far it does seem that the esp limp mode was caused from a faulty accelerator pedal module . On the scanner it would read out of range at wot so then putting the car in limp mode . I'll get to test it this weekend . But this problem seemed to have happened for a few others as well . Also the o2 sensors since there is long tubes on the car now we're not reading enough heat to turn the o2 heater off . So I just need to move the front two closer to motor , no big deal . I'll inform back from track this weekend if the limp mode happened again
Old Sep 20, 2017 | 03:40 PM
MOFLO's Avatar
^^^^ insightful information ^^^^
Please keep us updated. Thanks!
Old Sep 21, 2017 | 09:35 AM
PJK's Avatar
PJK
CLK63BS
What brand of LT headers are installed?
Thanks!
Old Sep 24, 2017 | 04:04 PM
  #32
2014 C63 Amg
Just finished a long two track days , no issues with limp mode . Seems the accelator pedal module was the problem , it's replaced and works much better . No sure of brand LT . Evosport put them in
Old Sep 24, 2017 | 04:06 PM
  #33
Tex5's Avatar
CLK 63 AMG Black Series, A45 AMG
Great
Old Sep 25, 2017 | 12:38 AM
  #34
COOPERDB's Avatar
NB8 PARACHUTE
Positive update
Knowledge is good
Emil Faber said that
Thank-You
D.B.
