How to tell when turbos kick in?
A large single turbo must spin-up to achieve efficiency. You can detect this when accelerating and it is known as turbo lag.
It's not that the turbo is not engaged, it's simply that it is not yet efficient Your butt-dyno can detect the RPM where the turbo seems to "kick-in".
Twin turbo technology aims to make the turbos more efficient at lower rpm's either by using parallel smaller turbos, or by using sequential turbos. The butt-dyno effect is that turbo lag is less apparent. Ideally, you can no longer detect when they "kick-in".
Regards,
Don
Starting from stop is touchy: too much throttle will cause ESP to step in.
adding a boost gauge is a great idea, but don't know where to put it: without buying and installing a new instrument panel.
