My build thread.
Old Apr 9, 2014 | 11:26 AM
threeMBs's Avatar
Only MBs - the best or nothing
Originally Posted by bigigg
Yes that's right, you mentioned that to me. I forgot how my front hub looked when I put my new wheels on. Just curious, 10mm spacer has a lip for wheel to sit on.. but spacer will still be sitting on very little hub lip? I think either way 5 or 10mm spacer doesn't seem to safe. Now I have a fear of my lug nuts failing..
No, that's the whole point of hubcentric spacers with centering lips by H&R and some others. They're 100% safe (same principal as all wheels). I would not spend time explaining why 5mm is not safe for MB's rear hubs and front hubs for 4matic only, and then recommend 10mm specifically for this application if they were (even somewhat) unsafe.
Old Apr 10, 2014 | 07:08 AM
bigigg's Avatar
14' CLS550
ok thanx.. i'll let you know how everything goes after Monday.
Old Apr 16, 2014 | 08:14 AM
bigigg's Avatar
14' CLS550
Update.. I'm still waiting on spacers to arrive. I'm very disappointed after a unsuccessful install Monday of the Renntech lowering module, rear lowered but not front. Friday I will be taking the car to a "Euro tuner" shop that claims they can install the module. I did get some satisfaction knowing that my rears wont rub after seeing the tire tucked all the way in the fender(literally 1mm of clearance) I think this is due to the negative camber when the car is that low. I plan on setting the speed function at 35mph so I wont get to bad of tire wear at higher speed.
Old Apr 20, 2014 | 12:43 PM
bigigg's Avatar
14' CLS550
Finally lowered!!
My mods are complete.. for now
Attached Thumbnails My build thread.-cls1.jpg   My build thread.-cls2.jpg   My build thread.-cls3.jpg   My build thread.-cls4.jpg   My build thread.-cls5.jpg
Old Apr 20, 2014 | 12:44 PM
bigigg's Avatar
14' CLS550
Few more cell phone shots
Attached Thumbnails My build thread.-cls7.jpg   My build thread.-cls8.jpg   My build thread.-cls9.jpg   My build thread.-cls10.jpg
Old Apr 20, 2014 | 06:09 PM
jett3jett's Avatar
2021 G63, 2016 S550, 2019 RR 👻
she looks good!! Love the white calipers & powder coating the stance wheels really made it pop
keep up the nice work!
Old Apr 20, 2014 | 07:18 PM
  #32
threeMBs's Avatar
bigigg, both front and rear look perfect.
Did you end up using spacers upfront and if yes which size?
What did you do in the rear of anything (fender roll, taking few mms from wheels' offset)?
Old Apr 20, 2014 | 09:32 PM
  #33
bigigg's Avatar
14' CLS550
Thank you Jett
Three.. used 10mm spacers in front. Rear fenders were rolled, but there isn't much of a lip back there to begin with. Combined with very slight negative camber when car is slammed, there's no rubbing. The front is the lowest the elm will allow,to be even with the rear it needs to drop about 1/4" inch. When I drive in sport mode I get a warning on dash that says "car too low". So I drive in comfort mode and put it in sport when I park.
Old Apr 20, 2014 | 10:58 PM
  #34
juliana21's Avatar
13 E350 4MATIC
P@nty Dropper
I told you Pimpin Ain't Easy
Old Apr 21, 2014 | 06:21 AM
  #35
bigigg's Avatar
14' CLS550
Jeff idk man.. modding is becoming more stressful than fun. I admit tho, this car puts a smile on my face every time. We need to plan that photo shoot.
Old Apr 28, 2014 | 07:22 PM
  #36
jett3jett's Avatar
Hows it going? I wanted to know how you like the new wheels so far.
I saw you were cutting it close with fitment, Did you have to make any further adjustments?
We've got to get together for a photoshoot one of these weekends!
Old Apr 29, 2014 | 06:46 AM
  #37
bigigg's Avatar
14' CLS550
Everything is great, thank you. I have no rubbing issues, my only complaint is with the front.. I'd like to be about 3/8" lower to match the rear drop but the front wont go any lower. I like the look of the tire actually tucked in the fender. You can see the slight difference in the pics. I drive in "comfort" mode, but when I park I put it in sport.
Old Apr 29, 2014 | 03:53 PM
  #38
jett2jett's Avatar
13' CLS550
I wasnt going to lower my car bc i have enough issues with these roads in the tri-state area plus i do a lot of driving. However you got me on my game. I didnt want to shell out the money for a module but i ordered links. Still deciding on a color to paint the calipers.... Im happy your enjoying your cls, you have really tied it together nicely. Cant wait to bring the cars together
Old Apr 29, 2014 | 04:03 PM
  #39
bigigg's Avatar
14' CLS550
Thank you. I know its not cheap, but I would def do a module instead of links. Having the option to raise the car at the push of a button is great.
Old Apr 29, 2014 | 04:08 PM
  #40
jett2jett's Avatar
13' CLS550
Your certainly right! Links is the cheap way of lowering it. I only plan on dropping it about an inch to lose the gap between the wheel well. My dealership can be iffy about modifications sometimes, the links are simple enough to swap back to stock incase i need to bring it in for service.
Going to spend the saved money on downpipes from seller A-M? listed in this forum if he ever sells them to me
Old Jun 12, 2014 | 05:00 PM
  #41
Spec_Davis's Avatar
W204 Color: 090 / 1999 Honda Civic EX / 2003 Acura TL
bigigg! Nice car and i see you already starting modding the CLS550. keep it up and i am loving the white on black look.
Old Jun 13, 2014 | 07:59 AM
  #42
bigigg's Avatar
14' CLS550
Thank you. As far as mods i'm done, maybe a different grill if i can find one. How you been? Haven't talked to you in a while..
