20x10.5 wheels all around on 2014 CLS550??
Old Mar 2, 2015 | 09:56 PM
^Blackout^'s Avatar
Mercedes Benz CLS550
Is it possible to put 20x10.5 wheels all around on the 2014 CLS550?
What tire size would I run on the front and do any mods need to be done?
I'm interested in doing vossen 20x10.5 concave wheels all around.
Old May 3, 2015 | 02:42 PM
^Blackout^'s Avatar
Question
Anyone??
I'm running 20x9 in the front now...
and 20x10.5 in the rear now...
anyway possible I can get a 20x10.5 to fit on the front wheels?
Has anyone here done this on their CLS? I would like a universal concanve look on all 4 wheels
Old May 7, 2015 | 01:07 AM
blue00r6's Avatar
2017 C43
You could fit them w/the right offset or spacer combo - but getting them to clear the control arm is going to cause them to poke out about 24mm beyond stock which will look stupid. not to mention you'll run the risk of bottoming out on your fenders depending on your ride height
Old May 7, 2015 | 05:13 PM
OSMS_Carlsson's Avatar
Former Vendor of MBWorld
Mercedes-Benz
BluOOr6 is right about the control arm. Many people who push to do 21's or 22's end up having to modify the body and suspension, and then at that point you are risking the function of the car. There is a difference between reality and functionality. Set your car up with the right application and you will enjoy the looks and performance.
10.5x20" wheels will not fit the front of a CLS550, you could maybe do this if you were running some sort of widebody kit, but even then you would be fitting the wrong tire combination...ideal set up is 8.5 or 9.0 front max. For the rear you can push to an 11.0 or the 10.5.
Hope this answers your questions.
Jim
Old May 10, 2015 | 03:58 PM
^Blackout^'s Avatar
Thanks for the info guys. I ended up running 20x9" (front) and 20x10.5" in the rear with 245/35/20 (front) and 285/30/20 (rear) tires.
I was told by some peeps at Vossen that I would have to roll the fenders, shave the bolt and actually (toe in) my camber to get the 20x 10.5" wheels to fit up front. I love the universal concave looks of the 10.5" all around but yes, I agree, not worth the headache.
Heres the ride:
