Wheel offset for CLS550
Old Oct 10, 2015 | 03:26 PM
f150ecobst's Avatar
2012 CLS550
Looking at purchasing some rims for my CLS. Can I run Front 20x9 ET32
2 Rear 20x10.5 ET42? This isn't the stock offset, so will this cause any issues?
Old Nov 2, 2015 | 11:56 PM
AZ_VET's Avatar
2012 CLS550
Depending on how wide of a tire it might be an issue in the back. You can check the clearance on "1010tires" website and use their Wheel Offset calculator. The other issue you may run into up front is a possible rubbing against the brake calipers depending on the style of rim. The default dimensions for the 19's are 19X8.5 ET34.5 up front and 19X9.5 ET48 on back. Hope this helps
