Mercedes CLS 350 2012 (Engine Light) P0191
Old Mar 3, 2016 | 02:56 AM
sambam2006's Avatar
GLC Coupe, S63L W222
Hi Guys,
I have a CLS 350 (2012), it's a diesel model.
I was driving around my local town and my engine management light came on, so I popped into my local Kwik fit store were I knew someone who helped me identify why the engine light was on:
The stored faults:
P0191 (Fuel Rail Pressure Sensor - Outside Specified Range)
The guy erased the faults, the engine light was reset. All was good for the rest of the day and then the following morning the engine light came back on.
Any ideas on this? Where is this located? Is it easy to replace? I don't have warranty either
See attached the pictures of the fault.
RESOLVED: PROBLEM WAS Engine Control Module (ECM), Replaced under warranty.
Old Mar 4, 2016 | 02:47 PM
sambam2006's Avatar
Originally Posted by Plutoe
To do it correctly---you should have the fuel delivery system(high pressure pump\fuel rail) pressure checked,however if you,want to do the job yourself, you need to remove the engine cover and expose the fuel rail\injector system--the rail sensor is at the rear of the passanger side rail--then remove lifting lug then remove sensor and reapply quickly as you do not want any crap in the injectors
Thanks for your reply
I have checked many things the past few days since posting this thread:
Put half tank of fresh 'ultimate diesal'.
Drove different speeds, 40, 60, 70, 80, 100, 110mph (no signs of any problems.
No error messages on the cluster instrument.
All electronic features work fine
Didn't find any leaks.
Things that caught my attention:
  1. Takes longer to start my car up (Cold starts only).
  2. A few times I have heard a clicking noise at low speeds after rough driving.
I will take a peak and try what you mentioned over the weekend.
