2012 CLS550 "Auxiliary Battery Malfunction"
Old Jun 22, 2016 | 04:05 PM
clm7214's Avatar
2012 CLS550
So I have been intermittently been getting a "Auxiliary Battery Malfunction" warning on the instrument cluster after letting the car sit for a few days. I was under the impression that there is only one battery in the W218 CLS. I know the main battery is in the engine compartment, as I had to disconnect it when swapping ECUs. Anyone have any words of wisdom as to where this auxiliary battery would be?
Old Jun 22, 2016 | 08:06 PM
mJstk01's Avatar
Small battery in the trunk inside the spare tire well needs to be replaced.
Old Jun 23, 2016 | 01:10 PM
konigstiger's Avatar
'71 Pinto
Backup for transmission selector, part # N000000004039 check dash, attached 212 instructions should be same for 218.
File Type: pdf
Old Jun 24, 2016 | 02:06 AM
TTMerc's Avatar
2014 CLS63 S
On a side note... I see your 2012 has "Manual Mode" Did it come with this or did you have it programmed to get it? I had a 2014 CLS that had it but my current one does not. Thanks for the info!
Old Jun 26, 2016 | 12:43 PM
hyperion667's Avatar
2012 CLS63
hi clm, I recently had the aux battery replaced in my CLS under warranty......hope it got fixed for you
