Retrofit Comand 5.1/5.5 & Carpaly into W218 2011-2014?
Old Feb 13, 2020 | 05:37 PM
vikislap's Avatar
Gla x156
Retrofit...
Hi Chris
so I finally enter pin code to the radio but it reseting all over again all the time any idea maybe wrong coding or I am missing something or its something bad with can on it? See video below...
thanks Vik
Old Dec 29, 2020 | 02:20 PM
PowerCls's Avatar
Cls250
Originally Posted by master_o
Hello,
I have a 2015 (built May 2015) W218 CLS63s. I am trying to anyhow make it possible to activate Apple CarPlay. My COMAND system seems not to be prepared for that. I have 2 regular USB ports in the arm rest. Non of them has the screen mirroring symbol.
I tried some OBD2 activation tool (seller said, it should work, starting at model year 04/2015) It did not work. (Other sellers say CLS class W218 12/2015 or even later).
Would it help to install the part # 246-820-38-00 OEM smart phone integration kit? Can I even connect that to my existing COMAND system? I also read, that my COMAND might not have sufficient memory to be able to handle Apple CarPlay. So much different information.
What would happen, if nothing from the upper thing would work, if I would replace the COMAND head unit with a MY 2016 or newer? What kind of issues I have to calculate in this scenario? What I would also like to know, what's the COMAND version I have (NTG 5.x), and which version supports the Apple CarPlay (COMAND NTG 5.x????)
I would appreciate any helpful feedback. Thanks!!!
Mine is from April 2015 ... I would also like to have carplay and I can't solve my problem.
