Brake upgrade for 2014 cls550
https://mercteil.com/products/22?mai...it=12&offset=0
Per this website the 63 amg will fit the cls https://mercteil.com/products/22?mai...it=12&offset=0
These cars already have pretty stout brakes, though I do think they lack feel. In normal street driving, even "spirited" street driving, you're unlikely to over heat them to the point they fade. But if you do manage that then switching to a harder compound pad will likely help (and might also help with "feel"), but at the expense of low speed initial bite. Harder compound pads work better when they're hot, not so much when they're cold so at lower speeds you'll find you'll need more pedal pressure than was necessary with the OE pads. As far as the discs go, the difference between brands is negligible when it comes to the disc's ability to influence how the car stops, and I would suggest if there is a measurable difference you'll never see it on the street. Higher quality discs may have less run out, may be better balanced, might have better painted finishes, but they're not going to make your whip stop any faster. The only exception are discs that have a metal compound that is softer than OE discs; they sacrifice long service life for higher friction.
Brake feel is influenced by many things; the master cylinder, the ABS module, the flexible lines, the calipers and how much they flex, the compound of the pads, the condition of the fluid. Assuming the fluid is in good condition and there is no air in the system, the biggest bang for your buck is going to be harder compound pads - but with their associated trade off when cold.
On the street the single biggest factor in hauling these cars down from speed to a dead stop in as short a distance as possible (and assuming brake fade isn't an issue at that moment) is the tires. With our completely OE brake systems you likely already know what happens at any speed when you crush the brake pedal; the ABS kicks in. And that means only one thing, the tires have reached the limit of their adhesion to the road surface. Spending money on calipers/pads/discs/lines etc won't slow or halt your car any faster if the real limitation is at the tire contact patches. Instead, spending money on a set of performance summer tires, with their softer compound rubber, will.
update : I already gotta get new rotors and pads after one year for the front. I’m thinking of racing brake just to try something different. Will update
I finally have power steering again. The issue was inside the steering rack there is a angle sensor and the tech beat on the old spindle to get the old tie rods out rather than using the appropriate tool.THis in turn severed the fragile wire inside and caused the electric steering to go out. New rack is almost $3,000 plus 800 install and alignment. If you or a tech decide to do front end work make sure you use the removal tool.
that is awesome.
I’d be interested in selling the brakes or providing leads for him off tunedmercedes.com. Maybe buying some too. Do you need to do tie rods for the new calipers?
For me i think i need to make some money to feed this MB habit. I really think this a great platform. I liked how the AMG drove. But i actually like the full air suspension and it’s a really nice GT. I dont see myself upgrading for a while, this might be a future classic. I totally get doing new brakes and getting to 700whp.
what part of the hub is too wide?
i was under the impression the knuckles were almost i denticle except for the larger caliper mounting holes and that the AMG have a smaller dist place then the regular 550 because of the caliper size and that you can just cut the dust plate down?
sorry for my ignorance
Mostly for looks, I hate that Mercedes used a floating caliper in the rear. Even my friends 2004 Lexus LS has a fixed 2-piston and it just looks much better
You can clearly see that they are a fixed caliper in the rear. Still need to save up for this upgrade but I am definitely going to tackle this when budget allows. Even with just a stage 1 tune stock brakes feel a bit weak.
It is a simple rear swap. Fronts are more difficult, which is why I didn't even attempt to do it. Just coat both front and rear and it will look great.
