Urgent! Help with rear lowering links install.
Old Aug 5, 2019 | 10:46 AM
CLS550TT's Avatar
12 CLS 550
Over the weekend I installed lowing links on my 12 CLS 550, the fronts and rears were a breeze. I had the vehicle on a hoist and removed each as directed. When we set the vehicle back down off the hoist, everything looked fine. After a quick test drive, the rears raised up really high, almost to full extension. I then tried putting the stock links back on but it didn't remedy the issue, it was still really high, pretty sure the rear air suspension was fully inflated. While the vehicle was on ground level, with the rear so high up, I could see the links, I pushed it down and the rear started to release air to level it out. It then bottomed out, releasing pretty much all the air. Not sure what's going on with the rear links, as the install was pretty straight forward. The rears unlike the fronts can pivot either inwards toward the diff or outwards toward the wheel, does anyone know the right way it should be pivoting? Is there anything else I should be doing to properly set them back in place? Can anyone take pictures of how their stock one looks or does anyone have pictures on how they should look properly installed? Please help as my vehicle is currently inoperable and sitting at the shop.
