Total loss of turn signal function
Old Nov 7, 2019 | 11:49 AM
Delbert's Avatar
03 G55 - 13' CLS550 - 90' 560SEC
Hi there, I am a long-time lurker of the forum but rarely post. I own a 2013 CLS550 4Matic (C218) and am having issues with various electronics on board.
I was wondering if anyone had some experience with having a "Blind Spot Assist Inoperative" and "Active Lane Keep Assist Inoperative" coming up, and then shortly disappearing after engaging the turn signal. These inoperative messages will then come back anywhere from 10 seconds to 10 minutes later and usually go away if I engage the turn signal. After 2 or 3 cycles of these messages coming and going, the messages stay on and my turn signals will completely fail to work. There is no response whatsoever to any input on the stalk, besides manual high-beam control. My mechanic discovered that there were no stored codes and that the rear sensors located on the back bumper are not corroded. I've included a pretty basic video of what happens. For background, the car has 102,000km and is from Alberta, Canada, where we have very terrible winters.
Any ideas or experiences would be greatly appreciated.
Video is uploaded here:
Thanks!
Old Nov 7, 2019 | 09:50 PM
Idklol69's Avatar
CLS400 4Matic EC Tuned
I've gotten the "Blind Spot Assist Inoperative" and "Active Lane Keep Assist Inoperative" when it was POURING rain. I'm from Vancouver, so that explains the rain. What I did was test to see if a car was beside me on the highway and then activate the signal to see if I would get the beeping, and I didn't. I was going to a store, so in the parking lot I turned the car off/on and it fixed itself. It hasn't happened to me since, but my wild guess is that terrible driving conditions (weather) has to play a role in the system not being able to function properly?
Old Nov 8, 2019 | 11:23 AM
Tbbt CLS's Avatar
2013 CLS550 4Matic OE Tuned
Delbert,
How old are your starting and backup batteries? I've read where owners have resolved electrical issues by changing the backup battery (located under the dash on the driver side). It's a size 14 sealed motorcycle battery. No particular knowledge on your faults, but it might be worth a try. Marv
Old Nov 22, 2019 | 12:45 PM
Tbbt CLS's Avatar
Delbert, any resolution on your problems? Marv
Old Dec 23, 2019 | 12:36 AM
Delbert's Avatar
So just an update, I ended up buying a used steering column module part #2129000016 off eBay and installing that, which has resolved the turn signal issue. The blind-spot monitoring inoperative remains, so now I will replace the rear sensors.
Old Dec 23, 2019 | 11:22 AM
Ryan B.'s Avatar
CLS 550
Those sensors are expensive, excluding the labor cost, so it may be worth the time to replace the battery first. I know when I owned a Jaguar, there were a number of electrical gremlins that made an appearance from time to time and they all were traced back to an insufficiently charged battery if the car sat unused for even short periods of time. It may not be the case with you, but certainly worth considering before you spend a bit of money of the sensors. You don't even have to replace your battery. Just put a battery tender on it over night to see if the issues go away.
Old Dec 24, 2019 | 02:29 PM
Arrie's Avatar
I agree 100% with changing the AUX battery. I drive a 2010 E550 with all options but night view assist. A couple of years ago I started getting this problem after starting the car in a cold morning where my Distronic, Lane Keep Assist and Blind Spot monitoring were inoperable. Stopping the car and re-starting fixed it all. As this happened only when it was cold weather I focused on the AUX battery as I had read in this forum that this little battery could be the culprit. I went to the dealer and got a new one for $65. I could have bought one for around $20 thru Amazon but went to get one from the dealer knowing for sure it is the correct one and fits in the small place where the bracket for it is.
After AUX battery change no issues at all.
I don't know where and what size the AUX battery in your car is as MB has changed this a couple of times in the past years. Mine is very small about 2" x 3" x 1" and it is located in the driver side end of the dash board.
Using a battery tender must be used right at the AUX battery as I don't think the two batteries are connected when the car is not running, i.e. charging the main battery does not charge the AUX battery.
