2012 CLS550 4Matic Bluedriver Scan Report (Should I buy?)
Old Nov 15, 2019 | 10:30 AM
BrooklynCPA's Avatar
C240 CLS500 CLS550 E350 S550 ML350
Exclamation 2012 CLS550 4Matic Bluedriver Scan Report (Should I buy?)
Hi guys,
I checked out a CLS yesturday and scanned using my OBD and got the following error codes. Should I stay away or are the faults fixable ?
Make: Mercedes-Benz Year: 2012
CLS550 4Matic
----Confirmed Trouble Codes Scan Report----
2 Confirmed Trouble Codes:
1. P0430
Catalyst System Efficiency Below Threshold Bank 2
2. P2540
Low Pressure Fuel System Sensor Circuit Range/Performance
----Pending Trouble Codes Scan Report----
1 Pending Trouble Codes:
1. P2540
----ZBE - Audio/COMAND operating unit (A40/9) Codes Scan Report----
1 ZBE - Audio/COMAND operating unit (A40/9) Trouble Codes:
1. B1506-2A
Check report for description.
----ISM - Shift module (A80) Codes Scan Report----
1 ISM - Shift module (A80) Trouble Codes:
1. P179A-16
----ENR - Electronic level control (N97) Codes Scan Report----
2 ENR - Electronic level control (N97) Trouble Codes:
1. C156F-00
2. C156B-00
----FSCU_EC - Control unit ''Fuel pump'' (N118) Codes Scan Report----
2 FSCU_EC - Control unit ''Fuel pump'' (N118) Trouble Codes:
1. P0627-00
The output for the fuel pump has an electrical fault or open circuit.
2. P2540-00
The signal for the pressure sensor of the low-pressure fuel circuit is implausible.
----IRS-HRA - Outer right rear intelligent radar sensor system (B29/5) Codes Scan Report----
1 IRS-HRA - Outer right rear intelligent radar sensor system (B29/5) Trouble Codes:
1. C1520-02
----MFK - Multifunction camera (A40/11) Codes Scan Report----
1 MFK - Multifunction camera (A40/11) Trouble Codes:
1. B23A8-13
----HKS - Tailgate control (N121/1) Codes Scan Report----
1 HKS - Tailgate control (N121/1) Trouble Codes:
1. B224E-60
----PTS - PARKTRONIC (N62) Codes Scan Report----
1 PTS - PARKTRONIC (N62) Trouble Codes:
1. B1230-95
The inner right rear distance sensor has a malfunction. The mechanical setup is not OK.
----SCCM - Steering column module (N80) Codes Scan Report----
1 SCCM - Steering column module (N80) Trouble Codes:
1. B1EB0-00
Lane Keeping Assist has a malfunction.
----SDAR - Satellite digital audio radio (N87/5) Codes Scan Report----
1 SDAR - Satellite digital audio radio (N87/5) Trouble Codes:
1. U1250
----ESA ''Driver'' - Electric seat adjustment ''Driver'' (N32/1) Codes Scan Report----
2 ESA ''Driver'' - Electric seat adjustment ''Driver'' (N32/1) Trouble Codes:
1. B1EBB-54
2. B1D90-31
----ESA ''Front passenger'' - Electric seat adjustment ''Front passenger'' (N32/2) Codes
Scan Report----
1 ESA ''Front passenger'' - Electric seat adjustment ''Front passenger'' (N32/2) Trouble Codes:
1. B1DAB-54
----DTA - (N123/4) Codes Scan Report----
1 DTA - (N123/4) Trouble Codes:
1. U1643
No CAN message was received from control unit "System diagnosis".
----ME - Motor electronics ''MED177'' for combustion engine ''M276'' (N3/10) Codes Scan Report----
1 ME - Motor electronics ''MED177'' for combustion engine ''M276'' (N3/10) Trouble Codes:
1. P0430-00
KAT2: Catalyst System Efficiency Below Threshold Bank 2 no sub type information
Old Nov 16, 2019 | 08:21 AM
ntwillie1's Avatar
07 TL, 05 350z, 08 MDX
What device specifically did you use to pull the codes and how much did it cost? Is it the lsb2? And would you recommend? Thank you.
Old Nov 18, 2019 | 02:53 PM
Bluedriver on Amazon
It is def worth it because it catches dealers who try an clear codes, whether a vehicle will pass inspection and makes sure all sensors are working
Old Nov 18, 2019 | 04:42 PM
ntwillie1's Avatar
Thanks man. I ordered one. Recently had my car tuned so curious about codes and specifically smog results.
