HELP with Codes
Old Oct 12, 2020 | 03:09 PM
Heyrozz's Avatar
Infiniti g37xs
Unhappy HELP with Codes
I replaced my battery and then my ac-air unit has no power. My radiator fan also runs on high all the time. Here are the codes i got.
P023B00- Actuation coolant pump of charge air cooler has a short circuit to ground
U016487- Communication with the air conditioning has a malfunction
U04244A- Implausible data was received from the air conditioning. The wrong component is installed
C164-00 Lost communication with heating venting and air conditioner control module
I reconnected the battery to make sure there wasn't a loose connection. The problem did not go away. Any help would be greatly appreciated.
