Jacking point
Old Dec 5, 2020 | 09:21 AM
Romann001's Avatar
CLS 500 w218
Jacking point
Does anybody know if this is jacking point in front CLS?? I know there are 2 of them on each side of a car..And if anybody knows if there is one in back of the car, it would be useful as well...
Old Dec 5, 2020 | 06:36 PM
Ghostty's Avatar
2005 SL500, 2015 CLS400
Do you mean underneath the trunk? I need to check, but i highly doubt it. I had to remove the spare tire a while ago and the entire trunk bottom is a plastic piece that can be removed ...
Also this piece looks like is made of plastic, unless i'm missing something.
Old Dec 6, 2020 | 02:03 AM
Romann001's Avatar
CLS 500 w218
Hi, this picture is taken underneat the engine ...it would be nice if there is lifting point under trunk as well...but i have no clue
Old Dec 7, 2020 | 07:34 AM
investinwaffles's Avatar
So first step is put the car in Lift mode if you have airmatic.
At the rear, I jack on the flat spot of the differential. If you have an AMG do not jack on the cooling fins, jack on the actual differential housing. I use a hockey puck to prevent scratching but a piece of wood works fine too.
There are 4 jacking points at each corner of the body, look just behind the front wheel and in front of the rear wheel under the side skirt of the car. You should see 4 rubber pads, those are the body lift points where I place jack-stands. You can get the jack stand to "notch" into the rubber jack pad so it is secure. Do an aggressive wiggle test to make sure the jack stands are seated properly and do not have any give or sway.
There is an additional center front lift point which is the picture you are showing. That one is totally fine to jack from (it is basically on the K-member of the engine I think), but again you need a piece of wood or hockey puck because it is slightly recessed and you will crush the plastic if you have a cup-style jacking pad. I still need to try one of the mercedes-style jack pad adapters that they sell on Amazon and such but honestly my system works pretty well for me
I don't have a low-profile long reach jack, so I usually jack off the chassis jack pads and put 4x4 blocks of wood under the tires, then move the jack to the center front jacking point to further lift the vehicle, remove the blocks of wood and I can put jack stands under the body jack points. I always have a wheel slid under the car as well in case the car somehow falls, the rear tires are way taller than my head is so it should prevent it from getting squished, LOL. Always have a failsafe in place
Old Dec 7, 2020 | 07:36 AM
hyperion667's Avatar
2012 CLS63
A good jack point?
hot babe abs - Page 203 - MBWorld.org Forums
Old Dec 7, 2020 | 06:42 PM
Dblok1113's Avatar
2014 CLS 550
you are too funny bro I caught that on the other post too about the taillights
Old Dec 8, 2020 | 12:44 AM
Romann001's Avatar
CLS 500 w218
thanks for goood tips...
