m276 cam timing code: P001985
Old Apr 8, 2021 | 06:16 AM
kaank's Avatar
CLS350
Exclamation m276 cam timing code: P001985
Hi.
I have a Mercedes CLS350 with the engine code M276.952. The check engine light is on, and its coming up with the code P001985.
I have changed 2 x camshafts, 2 x camshaft adjusters 2x solenoid in the left side and planted the oil check valves in both sides and changed chain tensioner in both sides. i havent changed the chain because it seems tight and fine. I have adjusted the timing with the special tool. But as soon as i start the car it runs fine in 1-2 minutes and then the camshaft position changes by itself in the left exhaust side. Any ideas what it can be? it makes me crazy. I have disassembled it all and reassembled it again 3 times now...
Anyone??
Old Apr 8, 2021 | 08:27 AM
chassis's Avatar
2017 GLE350 4MATIC
Originally Posted by kaank
Hi.
Anyone??
Have you looked closely at all cam-related electronic connectors for the presence of oil?
8 connectors:
4 cam position sensors
4 cam solenoids/magnets
These can fail, allowing oil into the harness and the oil can migrate into the ECU giving intermittent contact and erratic behavior.
Old Apr 8, 2021 | 01:52 PM
kaank's Avatar
CLS350
Checked all connectors - nothing to see. Its dry.
i found out that the last owner has been driving with the engine light on for a while. Could it be because the self adaption values need to be reset with a star diagnose tester?
Old Apr 8, 2021 | 10:27 PM
chassis's Avatar
2017 GLE350 4MATIC
With all of the work done on the cam drive it's likely the problem lies in there.
Old Apr 11, 2021 | 10:14 AM
cls5504matic's Avatar
C63 Vert
With everything you've done, I would replace the sensors. Maybe that is just me but it's fairly cheap.
Old Apr 12, 2021 | 05:20 AM
kaank's Avatar
CLS350
Originally Posted by cls5504matic
With everything you've done, I would replace the sensors. Maybe that is just me but it's fairly cheap. https://www.youtube.com/watch?v=2cFxijdblH4
I have tried to switch the places for the sensor - but it still says fail in the left exhaust side. So i dont really think the sensors is faulty. But maybe it is worth a try. 34 35 6 854 16834 35 6 854 168
Old Apr 12, 2021 | 10:42 AM
chassis's Avatar
2017 GLE350 4MATIC
If the problem remains after changing sensor positions, you have a mechanical problem with the cam drive - chains, tensioners, sprockets, adjuster magnets.
