Headlight Replacement 2012 CLS550 HELP?
Old Apr 7, 2022 | 01:47 PM
AlmightyyGio's Avatar
Genesis 5.0 rspec & Genesis 4.6
Ok so long story short i have a 2012 cls550 and i need to replace the passenger headlight. The part number says 2188205261 but online i see a bunch of the same headlights with a different part number. Will all the headlights work or only the one with the matching part number?
Old Apr 8, 2022 | 11:12 AM
ss3964spd's Avatar
2011 E550 (RIP), 2014 CLS 550C4
You need to replace the entire headlight assembly? If so I would look for the correct part number, unless you find that the original P/N has been superseded by a new P/N.
The CLS probably offered different headlight options. My 2014, for instance, has the "active curve lighting" headlights that turn for corners. What I don't know is if they all came with those or if they were an option.
Old Apr 8, 2022 | 11:31 AM
konigstiger's Avatar
'71 Pinto
As suggested need to replace with same part # if you want # confirmation provide VIN.
Old Apr 8, 2022 | 04:35 PM
Thanks yall, im just gonna go with the headlight I have. I believe I have the cornering headlights as well. As the other headlights dont have the night vision
