2006 cls 500
Old Jul 26, 2022 | 06:37 PM
msell80's Avatar
Cls500 2006
2006 cls 500
Need help or some idea's. Car is currently being worked on for rear right speed control sensor not reading. MB said it was the right rear axle and ABS right needing to be replaced. Other certified MB mechanic is telling me there's no possible way, they traced all of the readings and wires, the axle is sending signal, it is reading through the speed control sensor (also abs module also was replaced during recall a few years ago). He's narrowing it down to the ESP control module. Steering is in limp mode with limited power steering, can't use cruise control, and abs light is on. few questions, on the 06 cls do I need to get a new PROGRAMMED with vin esp or can I 'plug and play' a used one? I've read about 30 conflicting replies on old posts. Thank you!
Old Jul 27, 2022 | 11:35 AM
konigstiger's Avatar
'71 Pinto
Originally Posted by msell80
Car is currently being worked on for rear right speed control sensor not reading. MB said it was the right rear axle and ABS right needing to be replaced. Other certified MB mechanic narrowing it down to the ESP control module.
Anyone offering MB fault code(s)? Attached 211 sheet (same for 219) plug & play other than erasing stored codes. 219 should be posting here: https://mbworld.org/forums/cls-coupe-c219-65/
