High fuel trim, etc bank 2 too rich
Old Dec 7, 2025 | 07:30 PM
Billydv1's Avatar
2011 S550 4matic
Just wanted to post this for the next person who may run into this. Had the check engine light come on. Forgot the exact code but something about bank 2 too rich and looking at live data showed a very high positive fuel trim for bank 2 (driver's side). Knowing that these vehicles have the vacuum pump check valves that fail, before I even started, I ordered the check valve off Amazon, for $10 if I'm pulling it to check it, I mine as well replace it. Of course the plastic pipe that leads to the front broke so I replaced the entire thing from the check valve to the front vacuum device with a simple piece of tubing. I pulled the air filter housings off and checked the filters. Although they looked clean, when I put them up to the sky, absolutely no light was visible. Replaced the 2 air filters, erased the codes. Afterwards fuel trims were very close to zero, codes didn't come back.
