Metallic pads on drilled rotors
Old Dec 12, 2025 | 06:09 PM
Billydv1's Avatar
2011 S550 4matic
I was getting a rough shudder when braking hard on the highway. I knew the brakes had been done just prior to my acquiring this vehicle 2 months ago, looked like new rotors and pads. I was thinking maybe bad control arm bushings, like I've read on this forum but they didn't seem bad enough to cause what I was feeling. I decided to go with brakes and figured drilled rotors would be more likely to have a problem than the rear flat rotors. I was right. Brand new front rotors had overheating blue spots on the backside. New front rotors and ceramic pads, rockauto, $284 delivered with rotors, pads, hardware. Car stops perfect.
I believe oem is organic, but I truly believe ceramic is the best option
