CLS Coupe (C219) Discuss the CLS Coupe.
Do NOT use goo-gone
Old Apr 19, 2005 | 03:49 PM
lfranklin's Avatar
s600
Do NOT use goo-gone
Removing stickers? Goo-gone will also remove your paint! One owner has had positive results, I tried it and paint is damaged. Use a hair dryer to soften the plastic sticker, scrape with finger nails - don't try and talk your significant other into this - she will never forgive you. Blue Poly polishwax/cleaner takes the "sticky" right off and doesn't damage the paint.
Old Apr 19, 2005 | 03:53 PM
JDM's Avatar
JDM
2011 C300
W-D 40 works well, too.
Old May 18, 2005 | 10:59 AM
Charmie's Avatar
what about the airbag sticker that is on the visor. I troed taking it off and half was successfully removed. Now it looks crappy!
what can i use to remove the adhesive from that type of surface?
Old May 18, 2005 | 05:17 PM
hradvar's Avatar
Try denatured alcohol.
Old May 18, 2005 | 06:40 PM
lfranklin's Avatar
s600
do not use goo gone
Before you try any "solvents" try using the tape/decal itself. The sticky side of the tape will pick up small remaining bits of adhesive left behind. Put the tape over the remaining adhesive and pull sharply, at an angle. Before you use any solvent whatsoever, if you must - be sure and test it on some inconspicuous spot, so if it damages the material it won't be evident.DO NOT USE WD-40, IT IS PENETRATING OIL AND WILL SOAK IN.
