CLS Coupe (C219) Discuss the CLS Coupe.
airmatic sitting uneven
Old Jan 12, 2006 | 08:37 PM
TectiteE's Avatar
MGT, 12 CLS63 Launch
my rear passangerside gap is about a half a 1/4 in higher that of the rear driver side and even when i raise it up, theres still that 1/4" difference... anyone elses car sit like that?
Old Jan 12, 2006 | 09:01 PM
D2-AUTOSPORT's Avatar
Former Vendor of MBWorld
VIPER
In your sig I that you did the washers mod to lower the car, normally anytime you lower a car, one side sits lower than the other (in most cases its the drivers side that sits lower). Its one of the main reasons we use coilovers on all of our project cars since you can make detail adustments to balance it.
with the washers I believe you can fiddle with the rear sensor to even it out.
Could you post pics of your car with the Collectizone Wheels? Thanks in advance
Old Jan 12, 2006 | 09:28 PM
TectiteE's Avatar
well the links are the fronts which sit perfectly even, the rears which i didn't touch are the ones that sit uneven... i plan on bring the car to get the rears lowered via stardiag but its wierd how it sits higher on one side... btw i'll try to post pics of the car this weekend...
Old Jan 12, 2006 | 11:12 PM
jwkim80's Avatar
2011 C63(Euro-spec)
Have you try to park your at at perfectly even spot?
Airmatic has only one height adjument input for the rear(two for front..right and left)
It means rear is auto-leveled side by side.
The rear of Airmatic trys to stay parallel and this is why rear is almost uneven all the time.
So try to park your car and perfectly even spot and check the heights.
It should be same.
Old Jan 13, 2006 | 04:55 PM
asianeuphoria's Avatar
05 w211 w/appearance package and 19" presidentials
I had the same problem in my garage, theni thought it could be my garage so i went out to a parking lor and had a leveler with me, parked it where i thought it was level and the car was sitting equally all around.
Old Jan 13, 2006 | 09:30 PM
aniantchev's Avatar
2007 ML 320CDI
I had the same problem.
Old Jan 25, 2006 | 04:08 PM
TectiteE's Avatar
heres a quick pic taken today with my phone
Old Jan 25, 2006 | 04:11 PM
VIPER
Not bad, maybe you should do the links in the rear (or get a module) to even out the height a little more. And then take some nicer pics!! lol
Old Jan 25, 2006 | 04:17 PM
TectiteE's Avatar
i was thinking of putting the original links back and then use the stardiag to lower it. or i can see if i keep the fronts the same if the stardiag can just lower the fronts... not sure if you can do the latter though because i heard that the fronts and rears need to be the same height....i'll take better pics soon lolz, i just moved so my digicam is in a box somewhere and weathers been ****ty so no sense trying to take good pics yet...
Old Sep 3, 2006 | 11:50 PM
hotwiredbenz's Avatar
'07 s550 4matic
is there any way to even out the rear? I've got a Eclass with the same problem. Airmatic sits higher on passenger side by about 1/4" (both before and after dropping via star). Is there any way to mechanically adjust this? the fronts are perfect.
