Anyone knows the offset to the stock AMG wheel?
06 CLS AMG offsets, Front 18x8.5 ET-25.
Rear 18x9.5 ET-28. Hope this helps.
Thank you very much. There is a set of Lowenhart LD5, The rims size are 20x9 in the front with a 38mm offset and 20x10 in the rear with a 43mm offset. So it looks like they are not going to work on my car.Originally Posted by larryv
06 CLS AMG offsets, Front 18x8.5 ET-25. Member
I have Lowenharts also and the fronts are 20x9 ET-25 offset and the rear are 20x11 ET-33. I read that
the rears are 20x10 I am not sure of the offset but i would check to see if they are for a CLS and not a S-Class. Good luck.
the rears are 20x10 I am not sure of the offset but i would check to see if they are for a CLS and not a S-Class. Good luck.LarryV. Thanks for the input, I have decided not go with these sets of Lowenhart. I am going with iForged Flux 20x9 front and 20x11 in the rear, it will be here 4-6 weeks........yikes.
