Some question about left of front-center vents
Hi,
I recently found a problem with the left vent of the front-center. When I used auto mode, the winds coming from the left vent of the front center was strong. However, when I adjusted it manually to the center vents (adjusted the jog to point left), the winds coming from the left vent of the front center turned to be much weaker, while the right vent of front center remained the same strength. All situations above are under the setting with max fans. Does anyone have the same situation?
Thanks.
Pinyu
Thanks.
Pinyu
2009 997CS2, 2003 996TT, 2006 CLS 500 AMG, 2003 Jaguar S Type R
Pinyu,
I just recently took my CLS for sevice and complained about the same problem you just described and after they checked it, they gave the standard "everything is normal operating range". It just sounds like they didn't want to go throught the hassle of taking the dash board apart to check...I guess MB customer service hasn't changed a bit.
-AMGmag
-AMGmag
