s63 wheels on a cls500?
2006 cls500 wald kit
im gettin a really good deal just looking for some input these are off a 2008 s63 they are the stock 20's does anyone know if they will fit ? thanks alot
Former Vendor
Any AMG Thats Around..
Usually the fitment swap is as follows
SL - CLS
S - CL
CLK - E - (sometimes also with C and SLK)
221 wheels will work on 220's with (19in+ have to go with lower profile tires)
AMG car needs AMG wheels.... but non amg car can use AMG Wheels...
they all will usually bolt up but the offsets are different which would lead to 2 issues... either rubbing on the inside up against the upper control arms or shocks..... or sticking too far out of the fender....
so to answer your question... they should fit on, but where they sit under the car might be an issue.... the CLS houses a really wide rear wheel/tire setup... i have gone 11in in the back of these cars... so the s class wheel might be in the fender a little too much...
but let me know.... worse case senerio get a skinny hubcentric spacer if they are that good of a deal...
J
SL - CLS
S - CL
J
