CLS Coupe (C219) Discuss the CLS Coupe.
renntech module install
Old Jul 11, 2008 | 01:22 AM
dubbmw's Avatar
How hard is it to install the rentech lowering module to a cls500? Has anyone done it themselves or brought your cars into a shop to do it. I'm considering buying a module but not sure about the install. any info will be great!!!!
Old Jul 11, 2008 | 08:29 AM
khelawanb's Avatar
2006 CLS500 with 55 AMG motor, 2008 Infiniti G35, 2000 Plymouth Grand Voyager
I've had it done. You need to pull the carpet up on the front pass floor, then remove the metal base held by three plastic screws. You will get instructions and everything that you need to install it in the box. I was a little scared when I saw all of the wires back there, so I took my car to a place in Maryland to have it done. Works great. Make sure you get the new module, because at the end of the year they will offer a wired remote that you can use to change the ride hight without pulling out the module every time.
Old Jul 11, 2008 | 12:21 PM
dubbmw's Avatar
thanks for the info!! I didnt want to spend soo much on installation considering the module is running over
$1100
