CLS Coupe (C219) Discuss the CLS Coupe.
Air Suspension - disable feature?
Old 07-27-2008, 01:15 PM
bgatxy's Avatar
I did a search & found conflicting info. Can I (or dealer) disable the automatic raising and lowering of my 06CLS500? I actually like the car stance after I park and the car "lowers" itself. I read the car will continue to raise/lower even when lowering links are installed. Elsewhere, I read that after installing an electronic lowering module, the car does not raise/lower itself - can somebody confirm for me from personal experience? Tnx
Old 07-27-2008, 08:39 PM
MB Fanatic's Avatar
4 wheels
The car will automatically lower itself at freeway speeds and when you park. And if you install cheap lowering links (aka washers) you raise the risk of having total suspension failure (airmatic strut will fail). If you want to lower the car, have the dealer lower the Airmatic's settings by adjusting the voltage via SDS.
Old 07-27-2008, 10:47 PM
khelawanb's Avatar
2006 CLS500 with 55 AMG motor, 2008 Infiniti G35, 2000 Plymouth Grand Voyager
I have the renntech lowering module, and my car lowers itself after I park it.
Old 07-28-2008, 07:47 AM
Amituk's Avatar
CLS 320
Why is there an increased risk of strut failure with links?
Amit
Quick Reply: Air Suspension - disable feature?
