CLS Coupe (C219) Discuss the CLS Coupe.
Removing the command system
Old Sep 10, 2008 | 09:30 AM
Amituk's Avatar
CLS 320
Does anyone know who to remove the command system?
I want to replace it with a double din head unit.
Regards
Amit
Old Sep 10, 2008 | 12:55 PM
joeybenz106's Avatar
2007 cls 550
You can thank kevin M for this.
So you must remove your Comand unit, to do this follow these steps..(borrowed)
1. open the ashtray
2. pry the shifter wood panel up with your fingers at the ashtray
side...the panel is held in by clips at the front side - release these
clips by pulling the panel up...the rear of the wood panel comes out by
moving the panel forwards
3. unclip the 2 plastic clips at the front of the ashtray that hold
the ashtray in
4. take out the ashtray after the clips have been released
5. take off the connector at the back of the ashtray
6. take the 2 torx 20 screws out that hold in the CD changer/compartment box
7. disconnect the 3 connectors at the bottom of the CD changer
(only 1 connector if you don't have the CD changer) BEWARE not to bend
the fiber (amber colored)!!!
8. take out the CD changer/compartment box
9. unscrew the 2 torx 20 screws at the bottom side of the comand -
turn these screws counterclockwise till they don't go any further
(won't come out)
10. take out the comand by pulling it towards you
11. disconnect the connectors at the back...BEWARE not to bend the fiber!
https://mbworld.org/forums/showthrea...light=ipod+fix
Old Sep 11, 2008 | 08:24 AM
Amituk's Avatar
CLS 320
thanks for that..
Amit
