CLS Coupe (C219) Discuss the CLS Coupe.
Rotora Big Brake kit on CLEARANCE!
Old Jul 17, 2009 | 08:27 PM
VividRacing's Avatar
Former Vendor of MBWorld
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
Hey guys,
There's a set of ROTORA BBK available under clearance for your CLS C219
Features:
-Rotora billet aluminum alloy piston racing calipers with sequentially sized piston bore sizes engineered to each specific vehicle.
-Rotora billet aluminum hat with �floating� disc assembly to reduce heat related stress and unsprung weight.
-Rotora 2 piece vented heat treated directional vane disc system to improve airflow/cooling under severe braking. Slotted or drilled & slotted oversize discs (355x32mm) to ensure equal heat dissipation and increase thermal capacity while relieving the disc and brake pad surface free of excess debris.
-Rotora ceramic formulated pads designed for extreme street and track application with high co-efficient of friction and high temperature fade resistance.
-Rotora DOT compliant stainless steel braided brake lines to improve stiffer pedal feel and prevent brake hose expansion.
-Rotora carbon steel (SC45) mounting brackets (depending on application) and hardware.
Clearance Kits available in:
Front- 6 piston 14" - $2,695.00 $1,886.50
8 piston 15" - $3,695.00 $2,586.50
Rear- 4 piston 14" - $2,195.00 $1,536.50
4 piston 15"- $2,695.00 $1,886.50
**Sale price marked in RED
-2 sets left in RED & METALLIC BLUE Calipers with DRILLED/SLOTTED Rotors
Contact ME if you have any questions or to place an order - 480 966 3040 ext 228
Old Jul 20, 2009 | 06:50 AM
waltpage's Avatar
2006 CLS500
Does the kit replace the OEM brakes (CLS500), or would there need to be modification?
Old Jul 20, 2009 | 12:48 PM
It replaces your oem brakes, it's a full kit which comes with Calipers, 2pc disc rotors, Stainless steel brake lines, brake pads and all the hardware
Old Jul 20, 2009 | 07:38 PM
waltpage's Avatar
2006 CLS500
Does any1 know how much it would cost to replace the OEM rotors and pads for the front? I am interested in the price difference.
Old Aug 14, 2009 | 03:30 PM
Pm's replied!
RED calipers still available!
