CLS Coupe (C219) Discuss the CLS Coupe.
Changed tires while back...now how do i deactivate TPMS sensors
Old Jan 18, 2010 | 04:11 PM
erifly's Avatar
I changed my tires a little over a month ago. And about a few days after a bright red TPMS warning came on telling me to check my tires. I know i don't have TPMS in the new tires...so I need to deactivate the TPMS monitoring system. How do I go about doing this? I have read in this forum that it is included in one of the menus in the dash display..but I can't find it.
Old Jan 18, 2010 | 10:21 PM
Cyberous's Avatar
S 63
You don't need to deactivate, you just need to reset it as if you got a flat.
I just upgraded from 18" to 20" and it light up about two minutes into the first drive.
Here you go.
File Type: pdf
Old Jan 19, 2010 | 09:47 AM
konigstiger's Avatar
'71 Pinto
http://www.benzworld.org/forums/w219...ml#post3922073
Old Jan 19, 2010 | 02:23 PM
erifly's Avatar
Thanks for the help guys. I was looking through the wrong menu.
Old Jan 20, 2010 | 10:58 PM
rleepremier's Avatar
12 CLS63, 12 GLK350, 08 RR SPORT SC,
cyberous is that not just to reset the service warning? or are both the tire/rim reset in the same instructions? i read through the manual and it says something about oil but no mention of tires/rims.
Old Jan 21, 2010 | 10:21 AM
erifly's Avatar
I did it a couple of days ago. From what I remember(hopefully correctly), Simply all you need to do is use the menu button to scroll to the temperature in the dash and then scroll up to see available options.
