2009 cl63 rims fitment on CLS
My friend is in search of rims for his 2006 CLS 500. He is really interested in the cl63 5 stars.
My question is will they fit without any fitment issues??? will he have to change up the tire size or somthing?? is the offset good for his ride??
Any information is much appreciated.
2007 CLS550
Not sure which wheel you are referring to as "CL63 5 Stars." But the 2010 CL63 has 20" diameter AMG 5-Spoke Forged wheels and the 2010 CLS63 has 19" AMG Triple 5-Spoke wheels. For starters the diameter for these wheels is different from a CLS500 which has 18" diameter wheels. So his existing tires wouldn't fit these choices. The width on all CLS models (base, base with AMG Sport Package and AMG) is staggered at 8.5" front and 9.5" rear and the tire size differ according to the diameter and width of the wheel. I believe that the offset should be the same for the models discussed, but do not know for sure. I think the style wheel you refer to is available from Mercedes AMG in 18", 19" or 20". Keep in mind that the original wheels are equipped with a Tire Pressure Monitoring System (TPMS). It requires a sensor to be installed in the tire and wheel assembly for proper operation. You can use your original sensor from your original wheels, but will need to transfer it to the new wheels. If he buys aftermarket wheels, make sure the new wheels can accommodate the sensor.
2006 CLS500, 21" Interad Turismo Wheels, Renntech Lowering Module
so you guys are saying that these rims will fit with the oem CL63 tires?
here are the exact rims
http://media.nextautos.com/wp-conten...l63_main_2.jpg
2016 E550 Cab & 2011 GL 550 & 09 VROD Muscle & 06 Seadoo Speedster LE .......
Those wont it is the wrong offset.....u said CLS 63 wheels not CL 63......Cl shares same offset as S class sl and CLS have the same offset....
