CLS Coupe (C219) Discuss the CLS Coupe.
Tires Question on 20' HRE's. Will they work?
Old Apr 10, 2011 | 04:43 AM
JS-CLS550's Avatar
CLS550
I currently have 20' HRE 943R's on my CLS550
Front set up is 20x9 (+31 offset) with 245-35-20 tires
Rear set up is 20x11 (+25 offset) with 275-30-20 tires
I am thinking of changing out the tires both front and rear tires for couple of reasons. The tires size I want to use are:
Front 255-35-20
Rear 295-30-20
I work and live in greater LA area so there are lots of pot holes and bumps so I want to give my front wheels as much protection as possible. By changing the fronts to 255-35-20, because of the diameter and width of the tires, I am pretty sure it will give better protect against pot holes and bumps for my front wheels. I am also thinking of changing out the rear tires to because my current tires (275-30-20) give stretched look on my rear which I really don't like and also the guys who put my tires on told me that its not safe to drive around with stretched tires because there are not enough side wall sealing the air with the outer edge of the wheels so on a hard turn, it my leak air.
Both 255-35-20 and 295-30-20's are 27 inches in diameter which will make the front and rear even. My current setup 245-35-20 is 26.8 inches and 275-30-20 is 26.5 inches so there aren't much difference in diameter other than the tires will be little wider and little taller.
My car is currently dropped with Links which give me just tad less than 2 finger gap both in front and rear. I can always adjust up if needed.
Anyone have any idea if the new tires setup will work? Anyone currently running 255-35-20's in the front and 295-30-20's in the rear?
Any input will be greatly appreciate it.
Old Apr 13, 2011 | 10:41 PM
miraclewhip_cls's Avatar
CLS/cayenne S/M3 convert
Wrong Size IMO That"s to high offset in the front is high as well
255-30-20 front
305-25-20 rear
0r
295-25-20 Rear IMO!
Hankook V12 has a great deal going on tires i never tired them but alot forum members have good review
I like low profile side wall (not so tall in 30-25) i have pzero nice,grip,wet,dry but they wear out fast especially since the cls is lower i have neg camber issues. my tire set up is 255-30-20/ 295-25-20
Old Apr 13, 2011 | 10:47 PM
bigben320e's Avatar
CLS63 Designo Edition, Hyundai Genesis 3.8 , Veloster Turbo, CLS500(Sold), E320 (SMOKED) R500 (Sold)
If you run 35/30's on the CLS the speedometer will be off over 3%, which is not good. I ran 20's with the 255/30/20F 295/25/20 R and the ride was noticeably rough.
Going to 19's....
Old Apr 14, 2011 | 12:39 AM
JS-CLS550's Avatar
CLS550
I don't mind speedometer being off a little. Also on most every car out there, speedometers show higher speed than the actual speed that car is traveling at.
Old Apr 15, 2011 | 12:15 PM
UDWANIT2's Avatar
2016 E550 Cab & 2011 GL 550 & 09 VROD Muscle & 06 Seadoo Speedster LE .......
255/30/20 n 305/25/20 wil set it off nice........................handel nicer n even height all around....
Old Apr 16, 2011 | 12:51 PM
1benz0's Avatar
CLS550
I would go with these, only tires in size your looking for that comes with an 50K warrenty http://www.conti-online.com/generato...n,tabNr=1.html
Old Apr 16, 2011 | 02:58 PM
Inf4life's Avatar
in your Mom's car
Front 255-35-20
Rear 295-30-20
You'll want to go with 255/30/20 in the front and 305/25/20 in the rear. It will work out just fine. 275 is way too narrow in the rear for an 11" wheel.
Going to 19's....
Ben always crying. Lol.
