CLS Coupe (C219) Discuss the CLS Coupe.
CLS W219 Facelift LED Tail Lights modules
Old May 9, 2025 | 03:29 PM
  #276
TheFrenchy's Avatar
Originally Posted by BenzKr3W
I need a set
Could you shoot me a message. My email is doordashss1013@gmail.com or on here as well
Thanks @TheFrenchy
Hello,
i sent you a mail yesterday.
Cheers,
Frenchy.
Old May 15, 2025 | 09:44 AM
  #277
Jameraroxxd's Avatar
Originally Posted by TheFrenchy
Hello,
As promised on anoter thread, i'm happy to
Show you the video of the first Plug & Play module,
that allows you to swap your old Tail lights for the
LED Tail lights from the 2009+ facelift model.
Every lights work perfectly without generating any error on
Your Instrument Cluster.
To upgrade your tail lights, you'll have to remove the plastic traverse in the trunk to Access all bolts, and bend a little bit side carpets.
Then, unscrew the 5 bolts of the Tail light, swap it with the new one, fix it with the 5 bolts, plug the module on your OEM connector (harness of the car), without cutting anything, and plug the other connector (from the module) to your new Tail light. Then you'll just have to attach the module on the traverse bar above the rear SAM, and that's it !
http://www.youtube.com/watch?v=pzZyJ...e_gdata_player
As you will see on the video, the sample is not completely finished, need to drill a hole In the box to run wires Safely out of it.
Everything will be ok on the finished product.
Regards,
Frenchy.
Hello
I am interested in buying modules that allow you to replace the rear lights with LEDs for a Mercedes CLS C219, what is the cost of modules for both lights? Is it possible to ship to Poland? What are the payment options?Please reply to the email address:
jameraroxxd@op.pl
Kind regards
Old May 16, 2025 | 05:34 AM
  #278
AirMax94's Avatar
W219 CLS 500 I W176 A180
Hello Frenchy,
I‘m interested in the modules too.
Would be very happy about an E-Mail to baumannmax642@gmail.com .
Thank you in advance!
Max
Old May 16, 2025 | 06:16 AM
  #279
TheFrenchy's Avatar
Originally Posted by AirMax94
Hello Frenchy,
Max
Hello,
thank you for your message,
i sent you a mail.
Cheers,
Frenchy.
Old Jan 10, 2026 | 01:00 PM
  #280
Maxmeuns's Avatar
Module cls w219
Hello,
Regards,
Frenchy.
bonjour, je recherche se module ou en trouvé ?
