I have a pair of the facelift modules with the rear tail lights if anyone is interested located in California. I am trying to avoid spam so drop your email and I will contact you.
hey frenchy I would like one of the modules!
email me at ndouglas816@yahoo.com
thanks!!
@TheFrenchy I tried to message you it but it won’t let me send any private messages?? Just shoot me an email when you get a chance so I can get the modules from you!! thanks Frenchy!!
As promised on anoter thread, i'm happy to
Show you the video of the first Plug & Play module,
that allows you to swap your old Tail lights for the
LED Tail lights from the 2009+ facelift model.
Every lights work perfectly without generating any error on
Your Instrument Cluster.
To upgrade your tail lights, you'll have to remove the plastic traverse in the trunk to Access all bolts, and bend a little bit side carpets.
Then, unscrew the 5 bolts of the Tail light, swap it with the new one, fix it with the 5 bolts, plug the module on your OEM connector (harness of the car), without cutting anything, and plug the other connector (from the module) to your new Tail light. Then you'll just have to attach the module on the traverse bar above the rear SAM, and that's it !
As you will see on the video, the sample is not completely finished, need to drill a hole In the box to run wires Safely out of it.
Everything will be ok on the finished product.
Regards,
Frenchy.
Hi Frenchy,
I hope all is well.
I have inquired for the modules from you, however I didn’t receive any email.
would you please send me an eamil again in order to proceed with the order.
I am also interested in a pair of the tail light modules - please can you let me know if you have any currently available for shipping to the U.K.? My e-mail address is HashDaMan@protonmail.com.
Cheers,
Hash
Hello Hash,
i just sent you a mail with details,
Cheers,
Frenchy
