Front camber on stock CLS500
Hello,
I just had my CLS500 alignment adjusted because of a slight pull to the right. The service tech told me they can adjust it but I will need a front camber bolt to totally correct the problem. The front camber before adjustment was -1.7 and they got it -1.5 but it is still in the red. I think the specs calls for -1.2 to -1.5. Since the car is stock, why wouldn't the stock bolt be able to adjust to spec? Am I being scammed for service I don't really need? If it needs to be fixed, about how much am I looking to spend? Any help or suggestions would be great.
Thanks!
Thanks!
Received 4,435 Likes
'71 Pinto
Correct, bolt kit (part 000330018, 175 in diagram) will correct drift this thread discusses install on w211 http://www.benzworld.org/forums/w211...0-00-18-a.html
