CLS Coupe (C219) Discuss the CLS Coupe.
CLS 550 Wouldn't start this morning!
Old Jan 6, 2012 | 09:46 AM
ParanoidAndroid's Avatar
2007 CLS 550
Exclamation CLS 550 Wouldn't start this morning!
Hello - my first post here - thanks for taking the time to read about my issues..
I have a 2007 CLS 550, which this morning, just didn't want to start-up for me. I have key-less start and leading up to today, had a few problems occasionally with my key not being recognized for a few seconds (I assumed the battery in the key was dying).
This morning when I went to start my car - nothing - the engine attempted to turn over once but didn't manage to start. All the lights on the dash and the radio worked fine - leading me to believe it's not a battery issue (with the car at least).
I tried putting the key in the ignition and turning - and nothing..
Yesterday, while at a gas station, the car had some problems starting - but only for a few seconds - and then it fired right up..
I plan to take the car to the dealership, but I was wondering if anyone had any insight into what the problem might be? My key? Battery? Alternator? Starter Motor?
Any help or advice would be greatly appreciated - thanks!
Old Jan 6, 2012 | 12:21 PM
S500 Man's Avatar
White S63 AMG W/Designo Interior
Crank position sensor
Old Jan 6, 2012 | 12:22 PM
S500 Man's Avatar
Happened to my s500 easy fix
Old Jan 6, 2012 | 06:27 PM
2007 CLS 550
Thanks S500 Man - I got home from work (about 10 hours later) and the same thing is happening - all the lights on the dash are working fine, but no starting - no cranking at all...
I've tried a few of the things that I've read on the forum - using a different key, moving the steering wheel, trying in neutral - no luck..
Any ideas on how to trick the car to start so I can at least drive it to the dealership?
Thanks..
Old Jan 9, 2012 | 04:42 PM
S500 Man's Avatar
Dealer will tow car for free call mercedes roadside
Old Nov 11, 2013 | 03:02 PM
tqtrin3's Avatar
sl600 and cls550
can someone please help, my 2007 cls 550 won't start when I try to turn on the key, does not make any sound, engine just does not response...prior to this from time to time when I try to start engine, it does not start smơothly, make a few slow crank before it turn on but a few day ago, it just not response anymore....
Thanks in advance...
tqtrin3
Old Nov 26, 2013 | 12:05 AM
hillzline2's Avatar
CLS500
Old Nov 26, 2013 | 08:31 AM
GuestFromTampa's Avatar
W212 E250 BT 4M
tqtrin3
I would check the battery first.
Its in the trunk BTW
Old Jan 4, 2014 | 01:36 AM
buzescu's Avatar
2008 CLS550, 2001 C240
try the other key
