CLS Coupe (C219) Discuss the CLS Coupe.
HELP leaking washer fluid
Old Oct 3, 2012 | 02:45 AM
erniec's Avatar
cls350
Hey Guys, its my first post. SO HELLO!! I just got myself a used CLS350 and im loving it. Last night I filled the washer fluid reservior with tap water and some washer fluid to the brim. Probably less then 800ml(not sure what it is in US quartzs/ounces and the reservior is about 4500ml).
Right after, i saw a big puddle of soapy water right beneath the door sills on the side where the washer fluid reservior is located and when i checked the reservior, it had depleted considerably.
So have any of you guys experienced something like this and what would you recommend me looking into? I hope that it doesnt lead to something worst. Thanks in advance guys
Old Oct 3, 2012 | 06:42 AM
benzmodz's Avatar
W203 slightly modified
Obviously the hoses or container are damaged or the water pump has fallen out of its sealing rubber.
Easy fix.
