CLS Fog lamp issues?
M-B CLS550
I'm having a problem with my fog lamps that I cannot seem to find written up anywhere, I have a stock 2007 CLS550. When the lights are in "auto" mode, the lamps turn themselves off from time to time. I've seen them turn themselves off individually for no apparent reason. When I put them to "on" they both light, so both bulbs are fine. Anyone heard of a heat issue? Are my relays overheating? My mechanic is a bit baffled. Thanks.
RTFM![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
The corner-illuminating front fog lamps
will come on automatically depending
on the steering angle, even if you did
not switch on either turn signal.
If the corner-illuminating front fog
lamps came on automatically, they will
also go out automatically depending on
the steering angle.
the steering angle.
