How to check transmission oil level on Cls550 ?
Also where may I purchase a driver door handle the unlock button doesn't seem to function ?
It's a sealed unit. If the fluid gets low or there's a problem you would get a transmission error on the dash, But trans don't leak.
Do every 40k miles. It's not recommended its required. It's a seven speed so it's shifting 30%-40% more times than a regular trans. And the fluid is very expensive too.
